Thank you for your quick reply. I added below full logs.
--2023-09-09 14:19:32-- https://node.aapanel.com/install/3/fileinfo.sh
Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 2606:4700:3034::ac43:ab07, ...
Length: 5435 (5.3K) [application/octet-stream]
Saving to: ‘fileinfo.sh’
0K ..... 100% 36.0M=0s
2023-09-09 14:19:32 (36.0 MB/s) - ‘fileinfo.sh’ saved [5435/5435]
selecting download node...
Configuring for:
PHP Api Version: 20100412
Zend Module Api No: 20100525
Zend Extension Api No: 220100525
configure.in:34: warning: The macro AC_TRY_LINK' is obsolete.
configure.in:34: You should run autoupdate.
./lib/autoconf/general.m4:2920: AC_TRY_LINK is expanded from...
lib/m4sugar/m4sh.m4:692: _AS_IF_ELSE is expanded from...
lib/m4sugar/m4sh.m4:699: AS_IF is expanded from...
./lib/autoconf/general.m4:2249: AC_CACHE_VAL is expanded from...
aclocal.m4:301: PHP_RUNPATH_SWITCH is expanded from...
configure.in:34: the top level
configure.in:149: warning: The macro
AC_LANG_C' is obsolete.
configure.in:149: You should run autoupdate.
./lib/autoconf/c.m4:72: AC_LANG_C is expanded from...
aclocal.m4:5738: _LT_AC_LANG_C_CONFIG is expanded from...
aclocal.m4:5737: AC_LIBTOOL_LANG_C_CONFIG is expanded from...
aclocal.m4:3084: AC_LIBTOOL_SETUP is expanded from...
aclocal.m4:3066: _AC_PROG_LIBTOOL is expanded from...
aclocal.m4:3053: AC_PROG_LIBTOOL is expanded from...
configure.in:149: the top level
configure.in:149: warning: The macro AC_LANG_C' is obsolete.
./lib/autoconf/general.m4:2270: AC_CACHE_CHECK is expanded from...
aclocal.m4:3575: _LT_AC_LOCK is expanded from...
aclocal.m4:4196: AC_LIBTOOL_SYS_HARD_LINK_LOCKS is expanded from...
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me:${as_lineno-$LINENO}: WARNING: `$CC' does not support `-c -o', so `make -j' may be unsafe
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me: WARNING: `$CC' does not support `-c -o', so `make -j' may be unsafe
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me:${as_lineno-$LINENO}: WARNING: output file `$ofile' does not exist
aclocal.m4:4929: _LT_AC_TAGCONFIG is expanded from...
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me: WARNING: output file `$ofile' does not exist
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me:${as_lineno-$LINENO}: WARNING: output file `$ofile' does not look like a libtool script
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me: WARNING: output file `$ofile' does not look like a libtool script
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me:${as_lineno-$LINENO}: WARNING: using `LTCC=$LTCC', extracted from `$ofile'
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me: WARNING: using `LTCC=$LTCC', extracted from `$ofile'
configure.in:149: warning: back quotes and double quotes must not be escaped in: tag name \"$tagname\" already exists
configure.in:149: warning: The macro AC_LANG_CPLUSPLUS' is obsolete.
./lib/autoconf/c.m4:262: AC_LANG_CPLUSPLUS is expanded from...
aclocal.m4:5820: _LT_AC_LANG_CXX_CONFIG is expanded from...
aclocal.m4:5819: AC_LIBTOOL_LANG_CXX_CONFIG is expanded from...
configure.in:149: warning: back quotes and double quotes must not be escaped in: $as_me:${as_lineno-$LINENO}: WARNING: \
configure.in:200: warning: The macro `AC_CONFIG_HEADER' is obsolete.
configure.in:200: You should run autoupdate.
./lib/autoconf/status.m4:719: AC_CONFIG_HEADER is expanded from...
configure.in:200: the top level
autoheader: warning: autoconf input should be named 'configure.ac', not 'configure.in'
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for a sed that does not truncate output... /bin/sed
checking for cc... cc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether the compiler supports GNU C... yes
checking whether cc accepts -g... yes
checking for cc option to enable C11 features... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... yes
checking build system type... ./config.guess: unable to guess system type
This script, last modified 2008-01-23, has failed to recognize
the operating system you are using. It is advised that you
download the most up to date version of the config scripts from
http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
and
http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
If the version you run (./config.guess) is already up to date, please
send the following data and any information you think might be
pertinent to config-patches@gnu.org in order to provide the needed
information to handle your system.
config.guess timestamp = 2008-01-23
uname -m = aarch64
uname -r = 5.15.0-1040-oracle
uname -s = Linux
uname -v = #46-Ubuntu SMP Fri Jul 14 21:47:21 UTC 2023
/usr/bin/uname -p = aarch64
/bin/uname -X =
hostinfo =
/bin/universe =
/usr/bin/arch -k =
/bin/arch = aarch64
/usr/bin/oslevel =
/usr/convex/getsysinfo =
UNAME_MACHINE = aarch64
UNAME_RELEASE = 5.15.0-1040-oracle
UNAME_SYSTEM = Linux
UNAME_VERSION = #46-Ubuntu SMP Fri Jul 14 21:47:21 UTC 2023
configure: error: cannot guess build type; you must specify one
error
