Server version: 10.6.7-MariaDB-log
read_buffer_size=16777216
max_used_connections=1
thread_count=0
Thread pointer: 0x0
Attempting backtrace. You can use the following information to find out
where mysqld died. If you see no messages after this, something went
terribly wrong...
stack_bottom = 0x0 thread_stack 0x49000
/www/server/mysql/bin/mariadbd(my_print_stacktrace+0x2e)[0x555c625926ae]
mysys/stacktrace.c:213(my_print_stacktrace)[0x555c620d2805]
??:0(restore_rt)[0x7f6a70333cf0]
:0(GI_raise)[0x7f6a6f477acf]
:0(GI_abort)[0x7f6a6f44aea5]
:0(libc_message)[0x7f6a6f4b8cc7]
??:0(malloc_printerr)[0x7f6a6f4bffcc]
??:0(int_free)[0x7f6a6f4c226d]
??:0(OPENSSL_LH_free)[0x7f6a706ca621]
??:0(ENGINE_set_RSA)[0x7f6a7069aee5]
??:0(OPENSSL_cleanup)[0x7f6a706c3f03]
:0(run_exit_handlers)[0x7f6a6f47a26c]
:0(on_exit)[0x7f6a6f47a3a0]
sql/mysqld.cc:1875(mysqld_exit(int))[0x555c61e0a58f]
psi/mysql_socket.h:1035(inline_mysql_socket_setsockopt)[0x555c61e150d3]
??:0(__libc_start_main)[0x7f6a6f463d85]
??:0(start)[0x555c61e08a2e]
The manual page at https://mariadb.com/kb/en/how-to-produce-a-full-stack-trace-for-mysqld/ contains
information that should help you find out what is causing the crash.
Writing a core file...
Working directory at /www/server/data
Resource Limits:
Fatal signal 11 while backtracing
230906 10:04:23 mysqld_safe Starting mariadbd daemon with databases from /www/server/data
2023-09-06 10:04:23 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-09-06 10:04:23 0 [Note] /www/server/mysql/bin/mariadbd (server 10.6.7-MariaDB-log) starting as process 2229 ...
2023-09-06 10:04:23 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2023-09-06 10:04:23 0 [Note] InnoDB: Number of pools: 1
2023-09-06 10:04:23 0 [Note] InnoDB: Using generic crc32 instructions
2023-09-06 10:04:23 0 [Note] InnoDB: Using Linux native AIO
2023-09-06 10:04:23 0 [Note] InnoDB: Initializing buffer pool, total size = 4294967296, chunk size = 134217728
2023-09-06 10:04:23 0 [Note] InnoDB: Completed initialization of buffer pool
2023-09-06 10:04:24 0 [Note] InnoDB: 128 rollback segments are active.
2023-09-06 10:04:24 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-09-06 10:04:24 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-09-06 10:04:24 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-09-06 10:04:24 0 [Note] InnoDB: 10.6.7 started; log sequence number 42347; transaction id 14
2023-09-06 10:04:24 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-09-06 10:04:24 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-09-06 10:04:24 0 [Note] InnoDB: Buffer pool(s) load completed at 230906 10:04:24
2023-09-06 10:04:24 0 [Note] Server socket created on IP: '0.0.0.0'.
2023-09-06 10:04:24 0 [Note] Server socket created on IP: '::'.
2023-09-06 10:04:24 0 [Note] /www/server/mysql/bin/mariadbd: ready for connections.
Version: '10.6.7-MariaDB-log' socket: '/tmp/mysql.sock' port: 3306 Source distribution
2023-09-06 10:10:48 5 [Warning] Aborted connection 5 to db: 'unconnected' user: 'unauthenticated' host: '62-210-100-111.rev.poneytelecom.eu' (This connection closed normally without authentication)
