But now i got output from panel_path=/www/server/panel && sudo $panel_path/BT-Panel && sudo cat nohup.out
`stefanjacomeit@raspberrypi:~$ panel_path=/www/server/panel && sudo nohup $panel_path/BT-Panel && sudo cat nohup.out
nohup: ignoring input and appending output to 'nohup.out'
File "src/gevent/greenlet.py", line 906, in gevent._gevent_cgreenlet.Greenlet.run
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/baseserver.py", line 34, in _handle_and_close_when_done
return handle(*args_tuple)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/server.py", line 233, in wrap_socket_and_handle
with closing_socket(self.wrap_socket(client_socket, **self.ssl_args)) as ssl_socket:
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 120, in wrap_socket
session=session)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 312, in init
raise x
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 308, in init
self.do_handshake()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 666, in do_handshake
self.sslobj.do_handshake()
ssl.SSLError: [SSL: SSLV3_ALERT_CERTIFICATE_UNKNOWN] sslv3 alert certificate unknown (ssl.c:1091)
2023-09-04T06:50:33Z <Greenlet at 0xffffaf5b2a70: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaf41c4b)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:50:33Z <Greenlet at 0xffffaf5b2b90: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaf41c52)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:50:38Z <Greenlet at 0xffffaf4ab3b0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27f3)> failed with SSLError
session=session)
raise x
self.do_handshake()
ssl.SSLError: [SSL: HTTP_REQUEST] http request (ssl.c:1091)
2023-09-04T06:51:32Z <Greenlet at 0xffffaf4ab3b0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27f3)> failed with SSLError
session=session)
raise x
self.do_handshake()
session=session)
raise x
self.do_handshake()
session=session)
raise x
self.do_handshake()
2023-09-04T06:51:33Z <Greenlet at 0xffffaf4ab3b0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27f3)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:51:35Z <Greenlet at 0xffffaf4ab4d0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27fa)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:51:35Z <Greenlet at 0xffffaf4ab5f0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb4905)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:51:35Z <Greenlet at 0xffffaf4ab5f0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27fa)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:51:37Z <Greenlet at 0xffffaf4ab5f0: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27fa)> failed with SSLError
session=session)
raise x
self.do_handshake()
2023-09-04T06:51:37Z <Greenlet at 0xffffaf4ab710: handle_and_close_when_done(<bound method StreamServer.wrap_socket_and_handle , <bound method StreamServer.do_close of <WSGIServer, (<gevent.socket3.socket [closed] at 0xffffaeb27f3)> failed with SSLError
session=session)
raise x
self.do_handshake()
self._sslobj.do_handshake()
stefanjacomeit@raspberrypi:~$`
