Hello,
I've set up an Automatic backup in cron, under the Dashboard/Cron Job tab. While it works perfectly for MySQL, I've encountered an issue with pgSQL. In manual mode, under the Databases tab and in the Backup column, both databases back up just fine. I kindly request you to test and fix this bug.
Here are the logs for your reference:
MySQL Log:
|-Start backup[2023-09-01 00:00:01]
|-Backup database: ***********
|-Database size: 592.51 MB
|-Database character set: utf8
|-Partition / available disk space is: 15.27 GB, available Inode is: 4562343
|-Start exporting database: 2023-09-01 00:00:01
|-Compression completed, took 17.45 seconds, compressed package size: 43.02 MB
|-Database has been backed up to: /www/backup/database/db_***********_20230901_000001.sql.gz
|-Keep the latest number of backups: 5 copies
|-Expired backup files have been cleaned from disk: /www/backup/database/db_***********_20230827_000001.sql.gz
|-Backup completed[2023-09-01 00:00:19]
PgSQL Log:
|-Start backup[2023-09-01 21:58:58]
|-PgSqlThe database does not currently support backup
