Hamka Every time I set RAM on MySQL and save it, it will definitely change to zero. Im Use Ubuntu 22.04.2 LTS
aaPanel_Kern Hamka Hello, what is your mysql version? The higher version of mysql has removed this option
Hamka aaPanel_Kern When compared with MySQL vs MariaDB... ??? which one is better to use if there are around 10 thousand visitors? I used to use mariadb on Ubuntu 20 and the web or I didn't experience downtime when I got large visitors. Is MySQL also capable of that? Because now I'm using Ubuntu 22, so MariaDB can no longer be installed?
Hamka aaPanel_Kern When will mariadb support on aapanel using Ubuntu 22 OS? even though if we compare mysql vs mariadb, maridb is superior, especially in terms of performance
aaPanel_Kern Hello, it is recommended to use mysql, mariaDB has compatibility issues, if the installation is not successful, it cannot be used. MySQL 8 has deprecated query_cache_size, the reason is recommended to check the official website introduction Hamka
Hamka aaPanel_Kern Thanks info 🙏🙏🙏🙏 does this mean that mariadb will no longer support aapanel on ubuntu 22 ???
