Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
-bash: Reading: command not found
root@svr1:~# Some packages could not be installed. This may mean that you have
-bash: Some: command not found
root@svr1:~# requested an impossible situation or if you are using the unstable
-bash: requested: command not found
root@svr1:~# distribution that some required packages have not yet been created
-bash: distribution: command not found
root@svr1:~# or been moved out of Incoming.
rspamd : Depends: libc++1-16 (>= 1:16.0.0~++20230308013049+7b4e71bcf991) but it is not installable
-bash: or: command not found
root@svr1:~# The following information may help to resolve the situation:
-bash: The: command not found
root@svr1:~#
root@svr1:~# The following packages have unmet dependencies:
root@svr1:~# rspamd : Depends: libc++1-16 (>= 1:16.0.0~++20230308013049+7b4e71bcf991) but it is not installable
-bash: syntax error near unexpected token ('
root@svr1:~# Depends: libc++abi1-16 (>= 1:16.0.0~++20230308013049+7b4e71bcf991) but it is not installable
Tried using the below:-
CODENAME=lsb_release -c -s
mkdir -p /etc/apt/keyrings
wget -O- https://rspamd.com/apt-stable/gpg.key | gpg --dearmor | tee /etc/apt/keyrings/rspamd.gpg > /dev/null
echo "deb [arch=amd64 signed-by=/etc/apt/keyrings/rspamd.gpg] http://rspamd.com/apt-stable/ $CODENAME main" | tee /etc/apt/sources.list.d/rspamd.list
echo "deb-src [arch=amd64 signed-by=/etc/apt/keyrings/rspamd.gpg] http://rspamd.com/apt-stable/ $CODENAME main" | tee -a /etc/apt/sources.list.d/rspamd.list
apt-get update
export DEBIAN_FRONTEND=noninteractive
apt-get --no-install-recommends install rspamd -y
How do I get it installed.
Please help here.
