aaP_techno Installed the panel on pc ubuntu. Started it - it works. I restart PC, run the command bt "3" in the console, but it is no longer available at the previous ip address.
aaPanel_Kern Hi, I suggest you describe the problem in detail. Is there any error? is there any error executing this command? panel_path=/www/server/panel && sudo nohup $panel_path/BT-Panel && cat nohup.out aaP_techno
aaP_techno Solved the problem. I entered the bt command and selected 14. The last digits of the IP address have been changed in the login information. Is it possible to make a local IP permanent ?
aaPanel_Kern This is caused by the change of your system IP. It is recommended to check whether to set a fixed IP aaP_techno
