aaP_tommychan_ckw I had tried this domain in another aapanel, it is working. Please help me how to solve this problem.
aaPanel_Kern Hello, the information shows a 502 error. It is recommended to check whether the website configuration is correct? For ssl problems, please check whether you have used redirection, URL rewirte? aaP_tommychan_ckw
aaPanel_Kern aaPanel_Kern It is recommended to check whether the website configuration is correct? The ssl provider cannot access your domain name. It is recommended to use dns to verify the application. aaP_tommychan_ckw
aaPanel_Kern Select dns verification, after adding relevant records according to the prompts, do not close this window and wait for the domain name records to take effect before proceeding with verification aaP_tommychan_ckw
aaPanel_Kern You need to wait for the txt record to take effect before you can press the application aaP_tommychan_ckw
aaPanel_Kern Hello, I suggest you check the configuration of the site. It cannot be accessed using https. Is port 443 open? Is it okay to try to delete port 443 and release it again? aaP_tommychan_ckw
