Hi @aaPanel_Kern
Please fix the telegram bot when have FIX panel
, use BT 16
and UPDATE PANEL
got broken on telegram bot can't use
here the log
>Send Content: Testing Send
[2023-08-26 00:48:47][DEBUG] - 错误信息为:Traceback (most recent call last):
File "/www/server/panel/class/msg/tg_msg.py", line 212, in send_msg
loop.run_until_complete(self.send_msg_async(bot_token, chat_id, msg))
File "/www/server/panel/pyenv/lib/python3.7/asyncio/base_events.py", line 587, in run_until_complete
return future.result()
File "/www/server/panel/class/msg/tg_msg.py", line 174, in send_msg_async
bot = telegram.Bot(token=bot_token)
AttributeError: module 'telegram' has no attribute 'Bot'
on 2 instance server i was used
Ubuntu 22.04.2 LTS x86_64(Py3.7.8)
Ubuntu 22.04.2 LTS aarch64(Py3.7.8)
i was used AARCH64
server and x86_64
Both are same when make UPDATE
, FIX
and BT16
Panel - Broken the Telegram BOT
please fix this - asap.
for that i always setup install bot manually to fix this - btpip install python-telegram-bot==20.3 -I && bt 1
So i want next fix can make auto install / fix the telegram bot when UPDATE, FIX, and BT16 Panel.
Thanks
