aaP_ankapweb I have installed nginx 1.24.0 on my server and everything works fine. After the installation of Nginx WAF there is a conflict in the configuration of nginx for the lua_package_path as you can see in the attached image. What should I do ? Thanks
aaPanel_Kern Hi, try to reinstall nginx. Please select compilation mode during installation, and then install nginx waf, is it normal? aaP_ankapweb
aaP_ankapweb Unfortunately no my friend, this cause me a lot other problems. I rolled back to the previous state with nginx 1.21.4 and everything is working fine Thank you again
shahinsafari aaPanel_Kern Hi, I have this problem too On nginx 1.24 and the free nginx firewall No, I can reset And not to edit nginx When I remove the firewall The problem is solved
haris aaPanel_Kern may i know what is the correct steps to fix this? im currently got the same error on nginx 1.24. 'switched' to 1.22, still the same error. Should i uninstall both nginx & the WAF first. then reinstall nginx 1.22, followed by the WAF?
aaPanel_Kern haris Should i uninstall both nginx & the WAF first. then reinstall nginx 1.22, followed by the WAF? haris
