aaPanel_Kern Hello, is it normal after trying to replace the theme with the default one and disable third-party plugins? aaP_dextinxd5
aaP_dextinxd5 and some plugins also not working and i hosted 1 wordpress for check in there all plugins are working
aaPanel_Kern Suggest you check if the php version you are using is compatible with the plugin? We recommend that you check your site error logs aaP_dextinxd5
