aaP_lucasbamlr I restarted the server, I can no longer access it, and in the terminal I get this error
aaPanel_Kern aaP_lucasbamlr Hello, is there any error executing this command? panel_path=/www/server/panel && sudo nohup $panel_path/BT-Panel && cat nohup.out
aaP_lucasbamlr I used the installation command, but it still doesn't work, and that command you passed doesn't either
aaPanel_Kern Hello, what version is your system? You can execute the command to check hostnamectl The information shows that the python library was not installed successfully aaP_lucasbamlr
aaP_lucasbamlr second time this happens and I have to backup and reinstall the panel again this happens more when i update or repair the panel
aaPanel_Kern CentOS 8 officially does not do any maintenance, it is recommended to replace the system aaP_lucasbamlr
