Error logs in /www/server/data/myhost.err:
2023-08-18T22:27:58.527462Z 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-08-18T22:27:58.529313Z 0 [Warning] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2023-08-18T22:27:58.529324Z 0 [Warning] 'NO_AUTO_CREATE_USER' sql mode was not set.
2023-08-18T22:27:58.529352Z 0 [Note] --secure-file-priv is set to NULL. Operations related to importing and exporting data are disabled
2023-08-18T22:27:58.529763Z 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.7.40-log) starting as process 498185 ...
2023-08-18T22:27:58.580777Z 0 [Note] InnoDB: PUNCH HOLE support available
2023-08-18T22:27:58.580830Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2023-08-18T22:27:58.580835Z 0 [Note] InnoDB: Uses event mutexes
2023-08-18T22:27:58.580854Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2023-08-18T22:27:58.580857Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2023-08-18T22:27:58.582311Z 0 [Note] InnoDB: Number of pools: 1
2023-08-18T22:27:58.583579Z 0 [Note] InnoDB: Using CPU crc32 instructions
2023-08-18T22:27:58.585472Z 0 [Note] InnoDB: Initializing buffer pool, total size = 256M, instances = 1, chunk size = 128M
2023-08-18T22:27:58.616046Z 0 [Note] InnoDB: Completed initialization of buffer pool
2023-08-18T22:27:58.624931Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2023-08-18T22:27:58.642528Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2023-08-18T22:27:58.650295Z 0 [Note] InnoDB: Log scan progressed past the checkpoint lsn 356030500
2023-08-18T22:27:58.650312Z 0 [Note] InnoDB: Doing recovery: scanned up to log sequence number 356030509
2023-08-18T22:27:58.650317Z 0 [Note] InnoDB: Database was not shutdown normally!
2023-08-18T22:27:58.650321Z 0 [Note] InnoDB: Starting crash recovery.
2023-08-18T22:27:58.696349Z 0 [Note] InnoDB: Last MySQL binlog file position 0 35526665, file name mysql-bin.000007
2023-08-18T22:27:58.935678Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2023-08-18T22:27:58.936331Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2023-08-18T22:27:58.936395Z 0 [Note] InnoDB: Setting file '/www/server/data/ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2023-08-18T22:27:59.041365Z 0 [Note] InnoDB: File '/www/server/data/ibtmp1' size is now 12 MB.
2023-08-18T22:27:59.043630Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2023-08-18T22:27:59.043646Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2023-08-18T22:27:59.044360Z 0 [Note] InnoDB: Waiting for purge to start
2023-08-18T22:27:59.096056Z 0 [Note] InnoDB: 5.7.40 started; log sequence number 356030509
2023-08-18T22:27:59.096505Z 0 [Note] InnoDB: Loading buffer pool(s) from /www/server/data/ib_buffer_pool
2023-08-18T22:27:59.098588Z 0 [Note] Plugin 'FEDERATED' is disabled.
2023-08-18T22:27:59.109878Z 0 [Note] Recovering after a crash using mysql-bin
2023-08-18T22:27:59.121512Z 0 [Note] InnoDB: Buffer pool(s) load completed at 230818 22:27:59
2023-08-18T22:27:59.422426Z 0 [Note] Starting crash recovery...
2023-08-18T22:27:59.425362Z 0 [Note] Crash recovery finished.
2023-08-18T22:27:59.613340Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2023-08-18T22:27:59.613677Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
2023-08-18T22:27:59.613723Z 0 [Warning] A deprecated TLS version TLSv1 is enabled. Please use TLSv1.2 or higher.
2023-08-18T22:27:59.613730Z 0 [Warning] A deprecated TLS version TLSv1.1 is enabled. Please use TLSv1.2 or higher.
2023-08-18T22:27:59.615907Z 0 [Warning] CA certificate ca.pem is self signed.
2023-08-18T22:27:59.616319Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
2023-08-18T22:27:59.617362Z 0 [Note] Server hostname (bind-address): '*'; port: 3306
2023-08-18T22:27:59.617447Z 0 [Note] IPv6 is available.
2023-08-18T22:27:59.617462Z 0 [Note] - '::' resolves to '::';
2023-08-18T22:27:59.617488Z 0 [Note] Server socket created on IP: '::'.
2023-08-18T22:27:59.662375Z 0 [Note] Failed to start slave threads for channel ''
2023-08-18T22:27:59.707821Z 0 [Note] Event Scheduler: Loaded 0 events
2023-08-18T22:27:59.709492Z 0 [Note] /www/server/mysql/bin/mysqld: ready for connections.
Version: '5.7.40-log' socket: '/tmp/mysql.sock' port: 3306 Source distribution
2023-08-18T22:28:07.858577Z 0 [Warning] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824
2023-08-18T22:28:07.860593Z 0 [Warning] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
2023-08-18T22:28:07.860605Z 0 [Warning] 'NO_AUTO_CREATE_USER' sql mode was not set.
2023-08-18T22:28:07.860941Z 0 [Note] --secure-file-priv is set to NULL. Operations related to importing and exporting data are disabled
2023-08-18T22:28:07.861261Z 0 [Note] /www/server/mysql/bin/mysqld (mysqld 5.7.40-log) starting as process 498231 ...
2023-08-18T22:28:07.935193Z 0 [Note] InnoDB: PUNCH HOLE support available
2023-08-18T22:28:07.935231Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2023-08-18T22:28:07.935239Z 0 [Note] InnoDB: Uses event mutexes
2023-08-18T22:28:07.935243Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2023-08-18T22:28:07.935247Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
2023-08-18T22:28:07.936781Z 0 [Note] InnoDB: Number of pools: 1
2023-08-18T22:28:07.938122Z 0 [Note] InnoDB: Using CPU crc32 instructions
2023-08-18T22:28:07.943875Z 0 [Note] InnoDB: Initializing buffer pool, total size = 256M, instances = 1, chunk size = 128M
2023-08-18T22:28:08.134308Z 0 [Note] InnoDB: Completed initialization of buffer pool
2023-08-18T22:28:08.168523Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2023-08-18T22:28:08.226524Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2023-08-18T22:28:08.261089Z 0 [Note] InnoDB: Log scan progressed past the checkpoint lsn 356030518
2023-08-18T22:28:08.261392Z 0 [Note] InnoDB: Doing recovery: scanned up to log sequence number 356030537
2023-08-18T22:28:08.261857Z 0 [Note] InnoDB: Database was not shutdown normally!
2023-08-18T22:28:08.261867Z 0 [Note] InnoDB: Starting crash recovery.
