aaPanel_Kern avijit Hi, please use to check if security entrance is required? You can use the SSH tool to log in to the server and execute the command to view the default information: bt 14
avijit aaPanel_Kern Typo mistake. Its not 8080, Its 7800. I want o block access of port no 7800 in firewall. After blocking it's still accessible by ipv6.
aaPanel_Kern Hello, it should be caused by the fact that the firewall does not support ipv6, you can try to use the command to disable ipv6 port avijit
