ahmed_sm456 when i log in aapanel server it show me error (invalid user or password) as shown in this pic how can i reset password ..
aaPanel_Kern ahmed_sm456 Hi, please refer to this post You can use the ssh tool to execute commands to modify the user and password https://www.aapanel.com/forum/d/13132-aapanel-cannot-log-in-and-cannot-be-accessed-workaround
ahmed_sm456 aaPanel_Kern but how can i access this panel account i dont have linux os i have windows os
ahmed_sm456 aaPanel_Kern it installed in windows 10 but i install new windows from few days after that it cant be loggin how can i fix this problem
ahmed_sm456 aaPanel_Kern ok it may on linux i dont know it but how can i reset my password account .. can you do it by your self
aaPanel_Kern Where did you buy your server? It is recommended to consult the server provider ahmed_sm456
aaPanel_Kern Check the email sent by the server provider, which should contain the server information, or log in to the server provider’s website to check ahmed_sm456
ahmed_sm456 aaPanel_Kern you mean i must contact with Hetzner Teachnical Support Team to solve this problem .. ??
aaPanel_Kern ahmed_sm456 aaPanel_Kern Check the email sent by the server provider, which should contain the server information, or log in to the server provider’s website to check I suggest you check my reply
