Ceacer They used PHP FPM for file upload and modification, and I even purchased the Pro plugin but couldn't
aaPanel_Kern Ceacer Hello, is this the Tamper-proof for Enterprise plugin? If it is, it means that the interception has been successful.
Ceacer aaPanel_Kern The enterprise version anti-tampering plug-in, but it only intercepts part, so far my website is still being tampered with
aaPanel_Kern Ceacer Hello, the .txt file is not in the protection setting by default. It is recommended to restore the file first and then go to the relevant protection list to add the file suffix you need to protect to Protected file suffix
