aaP_297341 I uninstalled the already installed Apache and installed Nginx - Engine2.2.4. After installation, it showed a red stop status. I don't know why and how to solve it!
aaP_297341 Warning message: nginx: [alert] failed to load the 'resty.core' module (https://github.com/openresty/lua-resty-core); ensure you are using an OpenResty release from https://openresty.org/en/download.html (reason: module 'resty.core' not found: no field package.preload['resty.core'] no file './resty/core.lua' no file '/usr/local/share/luajit-2.1.0-beta3/resty/core.lua' no file '/usr/local/share/lua/5.1/resty/core.lua' no file '/usr/local/share/lua/5.1/resty/core/init.lua' no file './resty/core.so' no file '/usr/local/lib/lua/5.1/resty/core.so' no file '/usr/local/lib/lua/5.1/loadall.so' no file './resty.so' no file '/usr/local/lib/lua/5.1/resty.so' no file '/usr/local/lib/lua/5.1/loadall.so') in /www/server/nginx/conf/nginx.conf:10
aaPanel_Kern aaP_297341 Hi, is it ok to try to reinstall? Use compile mode to install when installing
aaP_297341 aaPanel_Kern The issue of using compilation still exists, and other versions are normal. You should check. I don't think it's my problem
aaP_297341 Reinstallation is not possible. All other versions are good, but Tengine cannot be installed. You should check it out
aaP_297341 I have verified my ideas on other newly installed panels, and this issue always exists, which should be the issue with this version!
