aaPanel_Kern Same
MariaDB 10.7 installation failed
avijit
Post link:
aaPanel_Kern Unfortunately I can't share panel information. I am facing this issue on 2 server after the update.
This problem has not been reproduced yet. If anyone else encounters the same problem, it is recommended to send the panel information to us for investigation
avijit
try:
execute command repair
bt 16
aaPanel_Kern Same.
Hello, only you have this problem at present, it is recommended to provide information for us to troubleshoot
aaPanel_Kern have you checked?
Hello, thanks for your feedback, this problem only exists in ubuntu 22, you can upgrade to beta version to solve this problem
I'm having the same problem.. is there a fix for this?
Hello, it is recommended to use mysql. mariaDB installation compatibility is too low
