aaPanel_Kern Hello, is it normal to try to execute the command to start? bt start Check if the bt service is running? bt status KrzysztofMaciejewski
KrzysztofMaciejewski aaPanel_Kern its something more and i cant figure it out its CentOS 8 vm on Windows 10 please help 🙂
aaPanel_Kern Hello, I don't see what the problem is. Does this problem affect the operation of the panel? KrzysztofMaciejewski
aaPanel_Kern KrzysztofMaciejewski Execute the command to check whether it is closed by the system? dmesg|grep -E "kill|httpd|apache|http|mysql|oom"
aaPanel_Kern aaPanel_Kern Execute the command to check whether it is closed by the system? dmesg|grep -E "kill|httpd|apache|http|mysql|oom" check look
aaPanel_Kern I don’t see what the problem is, what information does the inability to access prompt?
