[Sun Aug 06 06:00:44.639069 2023] [autoindex:error] [pid 870318:tid 281472996979072] [client 172.70.214.50:12278] AH01276: Cannot serve directory /www/wwwroot/cronfosis/: No matching DirectoryIndex (index.php,index.html,index.htm,default.php,default.html,default.htm) found, and server-generated directory index forbidden by Options directive
[Sun Aug 06 06:07:46.419016 2023] [ssl:warn] [pid 534483:tid 281473571319824] AH01909: SSL.cronfosis.in:443:0 server certificate does NOT include an ID which matches the server name
[Sun Aug 06 06:07:46.595576 2023] [ssl:warn] [pid 534483:tid 281473571319824] AH01909: SSL.cronfosis.in:443:0 server certificate does NOT include an ID which matches the server name
[Sun Aug 06 06:07:46.691566 2023] [ssl:warn] [pid 534483:tid 281473571319824] AH01909: SSL.cronfosis.in:443:0 server certificate does NOT include an ID which matches the server name
[Sun Aug 06 06:08:57.561470 2023] [authz_host:error] [pid 871761:tid 281473097625984] [client 172.71.182.116:10296] AH01753: access check of '.example.com' to /server-status failed, reason: unable to get the remote host name
[Sun Aug 06 06:08:57.561510 2023] [authz_core:error] [pid 871761:tid 281473097625984] [client 172.71.182.116:10296] AH01630: client denied by server configuration: /www/wwwroot/cronfosis/server-status
[Sun Aug 06 06:08:57.697289 2023] [access_compat:error] [pid 871761:tid 281473022091648] [client 172.71.98.185:42322] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.env
[Sun Aug 06 06:08:57.731891 2023] [access_compat:error] [pid 871763:tid 281473030484352] [client 172.71.182.95:15564] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.git
[Sun Aug 06 06:08:58.542851 2023] [authz_host:error] [pid 871762:tid 281473055662464] [client 172.70.230.36:12296] AH01753: access check of '.example.com' to /server-status failed, reason: unable to get the remote host name
[Sun Aug 06 06:08:58.542898 2023] [authz_core:error] [pid 871762:tid 281473055662464] [client 172.70.230.36:12296] AH01630: client denied by server configuration: /www/wwwroot/cronfosis/server-status
[Sun Aug 06 06:08:58.584749 2023] [authz_host:error] [pid 871762:tid 281473047269760] [client 172.70.110.236:15968] AH01753: access check of '.example.com' to /server-status failed, reason: unable to get the remote host name
[Sun Aug 06 06:08:58.584783 2023] [authz_core:error] [pid 871762:tid 281473047269760] [client 172.70.110.236:15968] AH01630: client denied by server configuration: /www/wwwroot/cronfosis/server-status
[Sun Aug 06 06:08:59.169256 2023] [authz_host:error] [pid 871762:tid 281473114411392] [client 172.70.110.80:17296] AH01753: access check of '.example.com' to /server-status failed, reason: unable to get the remote host name
[Sun Aug 06 06:08:59.169293 2023] [authz_core:error] [pid 871762:tid 281473114411392] [client 172.70.110.80:17296] AH01630: client denied by server configuration: /www/wwwroot/cronfosis/server-status
[Sun Aug 06 06:08:59.193612 2023] [access_compat:error] [pid 871762:tid 281473106018688] [client 162.158.154.156:54628] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.env
[Sun Aug 06 06:08:59.222111 2023] [access_compat:error] [pid 871762:tid 281473097625984] [client 172.70.230.63:65382] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.env
[Sun Aug 06 06:08:59.360869 2023] [access_compat:error] [pid 871761:tid 281473064055168] [client 162.158.62.195:54936] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.git
[Sun Aug 06 06:08:59.387523 2023] [access_compat:error] [pid 871762:tid 281473030484352] [client 162.158.63.10:32664] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.git
[Sun Aug 06 06:08:59.965795 2023] [access_compat:error] [pid 871761:tid 281473292026240] [client 162.158.155.70:38656] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.env
[Sun Aug 06 06:09:00.164797 2023] [access_compat:error] [pid 871763:tid 281473258455424] [client 162.158.63.166:48490] AH01797: client denied by server configuration: /www/wwwroot/cronfosis/.git
