radenvdka I did Additional IPv4 IP and after I added I opened aapanel using the new Additional IPv4 IP. however the capcha on the login page is not working properly resulting in a 404 response.
aaPanel_Kern radenvdka Hello, try to use the SSH tool to log in to the server and execute commands with root privileges, and then try again, can it be resolved? btpip install --upgrade Pillow bt reload
aaPanel_Kern aaPanel_Kern Hello, try to use the SSH tool to log in to the server and execute commands with root privileges, and then try again, can it be resolved? btpip install --upgrade Pillow bt reload aaP_jeet044
aaP_jeet044 even I am facing the same issue, whats the solution? Cannot it be directly managed by you guys?
