aaP_sagarkumarsahu60 Hi i have set panel login alram vai telegram and set two factor auth, but each time i can login though password directly with out asking otp even no login alram getting in telegram
aaPanel_Kern Hello, which one is set two factor auth? Is it normal to change browsers or use incognito mode to access? aaP_sagarkumarsahu60
aaPanel_Kern aaP_sagarkumarsahu60 Hello, please check the panel Operation logs for sending failure records, and check the panel Run logs for error logs?
aaPanel_Kern Log prompt: Chat not found Please check whether the set robot information is correct? aaP_sagarkumarsahu60
aaP_sagarkumarsahu60 aaPanel_Kern I have cross checked user id and token is correct , still unable to send test message
aaPanel_Kern Probably the reason is that the relevant robot was not found, it should be a problem with the robot information. Also check if python is ok? Are there more error messages? btpip list|grep telegram
aaPanel_Kern Hello, is the problem solved? If not, please check if the Bot information is correct? aaP_sagarkumarsahu60
aaP_sagarkumarsahu60 aaPanel_Kern i got the solution , after token id created, we need to start our own bot then only it will work
