aaPanel_Kern Kern I have new information, regarding the squema, is public with what is correct, but investigating more thoroughly achieve the following. Verify that effectively the user is postgres and the same has necessary permissions for the database
verify that it does not show me the relationships from terminal, so to the gnrep database, create by command the users table with id attribute and insert the 1 attribute as an example
From Sequelize run the query to show the data of that newly created table when in the controller "register" is requested
and surprise! from the console.log of the project node brought me the table data and did not show me the error
So verifying that the problem is not in the node code js and sequelize, but the tables are not being generated when performing the database import, because if I perform dt to the database should show me the database tables that I made the import? am I right?
I know I’m sending a lot of info, but I think it’s good that this record of postgresql nodejs and sequelize
