ha guys im facing this error i try fix option but this error. still coming
REQUEST_DATE: 2023-08-03 02:06:51
PAN_VERSION: 6.8.29
OS_VERSION: CentOS 7.9.2009 x86_64(Py3.7.9)
REMOTE_ADDR: 42.105.96.42
REQUEST_URI: POST /plugin?action=get_index_list
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 Edg/115.0.1901.188
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 170, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 73, in create_connection
File "src/gevent/event.py", line 306, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 336, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 324, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 304, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -2] Name or service not known
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 382, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1010, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 353, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 182, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -2] Name or service not known
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 573, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
File "/www/server/panel/BTPanel/init.py", line 1800, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1752, in run
File "class/panelPlugin.py", line 725, in get_index_list
softList = self.get_cloud_list(get)['list']
File "class/panelPlugin.py", line 366, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 119, in post
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
