OS - Rocky Linux release 9.2
/etc/init.d/mysqld status
ERROR! MySQL is not running
uname -a
Linux CRMTEST 5.14.0-284.18.1.el9_2.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Jun 22 17:36:46 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
MySQL server does not even try to start - the shutdown process is recorded in log, but there are no events when the server starts:
2023-08-01T10:37:00.580894Z 0 [Note] Giving 0 client threads a chance to die gracefully
2023-08-01T10:37:00.580916Z 0 [Note] Shutting down slave threads
2023-08-01T10:37:00.580922Z 0 [Note] Forcefully disconnecting 0 remaining clients
2023-08-01T10:37:00.580930Z 0 [Note] Event Scheduler: Purging the queue. 0 events
2023-08-01T10:37:00.581060Z 0 [Note] Binlog end
2023-08-01T10:37:00.583663Z 0 [Note] Shutting down plugin 'ngram'
2023-08-01T10:37:00.583681Z 0 [Note] Shutting down plugin 'partition'
2023-08-01T10:37:00.583685Z 0 [Note] Shutting down plugin 'BLACKHOLE'
2023-08-01T10:37:00.583689Z 0 [Note] Shutting down plugin 'ARCHIVE'
2023-08-01T10:37:00.583691Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2023-08-01T10:37:00.583729Z 0 [Note] Shutting down plugin 'MRG_MYISAM'
2023-08-01T10:37:00.583735Z 0 [Note] Shutting down plugin 'MyISAM'
2023-08-01T10:37:00.583747Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL'
2023-08-01T10:37:00.583751Z 0 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES'
2023-08-01T10:37:00.583753Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES'
2023-08-01T10:37:00.583755Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS'
2023-08-01T10:37:00.583757Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN'
2023-08-01T10:37:00.583759Z 0 [Note] Shutting down plugin 'INNODB_SYS_FIELDS'
2023-08-01T10:37:00.583761Z 0 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS'
2023-08-01T10:37:00.583763Z 0 [Note] Shutting down plugin 'INNODB_SYS_INDEXES'
2023-08-01T10:37:00.583765Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS'
2023-08-01T10:37:00.583767Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLES'
2023-08-01T10:37:00.583769Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE'
2023-08-01T10:37:00.583771Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE'
2023-08-01T10:37:00.583773Z 0 [Note] Shutting down plugin 'INNODB_FT_CONFIG'
2023-08-01T10:37:00.583775Z 0 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED'
2023-08-01T10:37:00.583776Z 0 [Note] Shutting down plugin 'INNODB_FT_DELETED'
2023-08-01T10:37:00.583778Z 0 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD'
2023-08-01T10:37:00.583780Z 0 [Note] Shutting down plugin 'INNODB_METRICS'
2023-08-01T10:37:00.583791Z 0 [Note] Shutting down plugin 'INNODB_TEMP_TABLE_INFO'
2023-08-01T10:37:00.583795Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS'
2023-08-01T10:37:00.583798Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU'
2023-08-01T10:37:00.583801Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE'
2023-08-01T10:37:00.583804Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET'
2023-08-01T10:37:00.583807Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX'
2023-08-01T10:37:00.583810Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET'
2023-08-01T10:37:00.583812Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM'
2023-08-01T10:37:00.583813Z 0 [Note] Shutting down plugin 'INNODB_CMP_RESET'
2023-08-01T10:37:00.583815Z 0 [Note] Shutting down plugin 'INNODB_CMP'
2023-08-01T10:37:00.583817Z 0 [Note] Shutting down plugin 'INNODB_LOCK_WAITS'
2023-08-01T10:37:00.583819Z 0 [Note] Shutting down plugin 'INNODB_LOCKS'
2023-08-01T10:37:00.583821Z 0 [Note] Shutting down plugin 'INNODB_TRX'
2023-08-01T10:37:00.583823Z 0 [Note] Shutting down plugin 'InnoDB'
2023-08-01T10:37:00.583890Z 0 [Note] InnoDB: FTS optimize thread exiting.
2023-08-01T10:37:00.583970Z 0 [Note] InnoDB: Starting shutdown...
2023-08-01T10:37:00.684122Z 0 [Note] InnoDB: Dumping buffer pool(s) to /www/server/data/ib_buffer_pool
2023-08-01T10:37:00.684320Z 0 [Note] InnoDB: Buffer pool(s) dump completed at 230801 13:37:00
2023-08-01T10:37:02.314233Z 0 [Note] InnoDB: Shutdown completed; log sequence number 2767115
2023-08-01T10:37:02.315355Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2023-08-01T10:37:02.315395Z 0 [Note] Shutting down plugin 'MEMORY'
2023-08-01T10:37:02.315438Z 0 [Note] Shutting down plugin 'CSV'
2023-08-01T10:37:02.315451Z 0 [Note] Shutting down plugin 'sha256_password'
2023-08-01T10:37:02.315457Z 0 [Note] Shutting down plugin 'mysql_native_password'
2023-08-01T10:37:02.315735Z 0 [Note] Shutting down plugin 'binlog'
2023-08-01T10:37:02.318970Z 0 [Note] /www/server/mysql/bin/mysqld: Shutdown complete
