im not sure if anyone is facing the same issue, just to share my experience.
recently i discovered that my machine is installing MySQL 8.0 automatically (yes, it's, because my i didn't initiate any MySQL installation in my aaPanel terminal) during #sudo apt update, sounds illogical, but i faced this issue for my 2 machines.
my server spec as below,
- alibabacloud simple application
- ubuntu 20
what happened was when I'm trying to install some application in the server, whether it is with aaPanel app store or from terminal, i realised that it has automatically installed MYSQL (I'm suspecting #sudo apt update is the culprit).
once the installation has done, everything works well until after i restarted the server, i realised that my MYSQL isn't working, I've tried all these methods,
https://www.aapanel.com/forum/d/15068-why-mysql-cant-start
https://www.aapanel.com/forum/d/1216-unable-to-start-mysql
https://www.aapanel.com/forum/d/3663-mysql-wont-start
https://www.aapanel.com/forum/d/16342-mysql-not-start
https://www.aapanel.com/forum/d/8862-mysql-is-not-starting
https://www.aapanel.com/forum/d/8862-mysql-is-not-starting/6
https://www.aapanel.com/forum/d/5443-mysql-not-starting
https://www.aapanel.com/forum/d/15304-mysql-stop-working
https://www.aapanel.com/forum/d/13159-unable-to-start-mysql-server
https://www.aapanel.com/forum/d/15068-why-mysql-cant-start/21
but none of them are working, until i realised that there is one MYSQL being installed in the terminal when I'm trying to do #mysql -V, the result shows MYSQL 8 being installed. by right, it should display,
in case your MYSQL isn't working, please try #mysql -V in your terminal and check if there is another MYSQL being installed.
to resolve this, you just need to uninstall the MYSQL in your terminal. (not the aaPanel version)
peace 😀
