When I have attempted to create a Docker container, with a variable that includes an equals sign, the process has failed, showing the below stack trace.
How may I define a variable with an equals sign in the value?
I am running version 6.8.29.
File "/www/server/panel/BTPanel/__init__.py", line 1800, in publicObject
File "/www/server/panel/BTPanel/__init__.py", line 1752, in run
File "class/panelController.py", line 81, in model
result = PluginLoader.module_run(module_name,def_name,pdata)
File "/www/server/panel/class/projectModel/dockerModel.py", line 52, in model
OO000OOOO000OOO0O =OOO0O000O0OOOOO0O (OO0O0O000O00O00O0 )#line:87
File "/www/server/panel/class/projectModel/bt_docker/dk_container.py", line 81, in run
environment=dp.set_kv(args.environment), #"HOME=/value\nHOME11=value1"
File "class/projectModel/bt_docker/dk_public.py", line 60, in set_kv
OOO00OO000O000000 ,OO00O0O00000OOO00 =OOOOO0OO00OO0O0OO .split ('=')#line:62
ValueError: too many values to unpack (expected 2)
