I think there is malware on the instance, event thought the websites are down, the CPU usage is over the roof. I just want to create the backups of the website and move it to a new instance.
It's not possible to login in the incognito mode, it's the same.
How to check the version of the aapenel?
Regarding bt 14:
' bt 14
EXECUTING
aaPanel default info!
aaPanel Internet Address: xxxx
aaPanel Internal Address: xxxx
File "/www/server/panel/tools.py", line 843, in <module>
set_panel_username()
File "/www/server/panel/tools.py", line 431, in set_panel_username
print('username: ' + username)
TypeError: can only concatenate str (not "NoneType") to str
password: ********
Warning:
If you cannot access the panel,
release the following port (7800|888|80|443|20|21) in the security group
bt 22:
"bt 22
EXECUTING
rv = self.dispatch_request()
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "/www/server/panel/BTPanel/init.py", line 1833, in login
result = userlogin.userlogin().request_post(get)
File "/www/server/panel/class/userlogin.py", line 155, in request_post
public.chdck_salt()
File "/www/server/panel/class/public/common.py", line 3552, in chdck_salt
pdata['password'] = md5(md5(u_info['password'] + '_bt.cn') + salt)
TypeError: string indices must be integers, not 'str'
[2024-08-20 10:15:17][DEBUG] - Traceback (most recent call last):
File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1823, in full_dispatch_request
File "/www/server/panel/BTPanel/__init__.py", line 1833, in login
public.chdck_salt()
[2024-08-21 09:53:10][DEBUG] - Traceback (most recent call last):
public.chdck_salt()
[2024-08-21 10:04:03][DEBUG] - Traceback (most recent call last):
public.chdck_salt()
[2024-08-21 10:09:46][DEBUG] - Traceback (most recent call last):
public.chdck_salt()
[2024-08-22 09:51:20][DEBUG] - Traceback (most recent call last):
public.chdck_salt()
