First, if you have problems installing the latest versions of php , i.e. version 8+, type the command below in your terminal with root user:
dnf install -y oniguruma
then, if you have problems starting nginx in the latest versions and you are not going to use the lua language, just comment out the line below in the plugin settings:
#lua_package_path "/www/server/nginx/lib/lua/?.lua;;";
to download the latest versions of the maria db, type the command below in your terminal with the root user:
sudo yum install -y gnutls
sudo yum install -y gnutls-devel
that's it for now.
instagram: @darlyssond
