aaP_sagarkumarsahu60 Os: 22 ubuntu aapanel version: Latest stable issue: cron error showing like this " /www/server/cron/e6aa4d8a518196131f3d59580ffc8e34: line 4: unexpected EOF while looking for matching `'' /www/server/cron/e6aa4d8a518196131f3d59580ffc8e34: line 9: syntax error: unexpected end of file"
aaPanel_Kern Hi, are you adding a shell script? Click Edit for the task to view the syntax aaP_sagarkumarsahu60
aaPanel_Kern aaPanel_Kern Hi, are you adding a shell script? Click Edit for the task to view the syntax aaP_shiv
aaP_shiv Hi, I am also getting the same error /www/server/cron/3f1d9e01f54493971f646b433637f6e6: line 10: unexpected EOF while looking for matching `'' I am getting this when my corn is executed. please help...
aaP_shiv It gets fixed, thanks for the quick update.. but I think it raises this issue in the case of the POST method in the GET method it is working well.. any suggestions?
