aaP_khairul_bestweb Hi everyone. I wonder if anyone have succeeded installing puppeteer npm package using AApanel? I tried using terminal but showing this error: I also try to search this module on PM2 manager but somehow not working as well
aaPanel_Kern Hello, the log prompts that the permissions are insufficient. Are you using the root user to execute?
aaP_khairul_bestweb aaPanel_Kern Yes im using root user to install these modules "npm install puppeteer"
aaP_khairul_bestweb aaPanel_Kern Right now, i try to install pupeteer and chromium manually. But somehow when i try to run the code, it said that Chromium is not found I couldn't see any .cache folders inside www. is it something need to create?
