Hello,
I have a PG DB from Digital Ocean and it's host is an URL instead of an IP address.
It's PORT is also different than the default 5432.
But it fails to connect and I am getting this error:
"status": false,
"msg": "Connecting to remote PGSQL fails. Perform the following operations to rectify the fault:
1. The database port is correct and the firewall allows access
2. Check whether the database account password is correct
3. pg_hba.confWhether to add a client release record
4. postgresql.conf Add listen_addresses to the correct server IP address."
