shahin_knavas my aaPanel is not getting a login. it's stuck in the loading after clicking the login button.
aaPanel_Kern shahin_knavas Hi, please check if you access the panel with the complete link, you can use the command bt 14 Are there any errors when executing the command?
shahin_knavas yes, I am using the correct path. there are no errors while executing the command. it is returned the URL to the panel.
aaPanel_Kern Hello, is this the problem? https://www.aapanel.com/forum/d/17173-cant-login-to-the-panel-404-not-found/3
