JAY
Hello, trying to install manually should be an error in the automatic installation process, try to install manually
Replace 74 with your version, without the dot in the middle
php_version=74
echo /www/server/php/${php_version}/src/ext/zip
cd /www/server/php/${php_version}/src/ext/zip
/www/server/php/${php_version}/bin/phpize
./configure --with-php-config=/www/server/php/${php_version}/bin/php-config
make && make install
if [ "${php_version}" == "73" ];then
extFile="/www/server/php/73/lib/php/extensions/no-debug-non-zts-20180731/zip.so"
elif [ "${php_version}" == "74" ]; then
extFile="/www/server/php/74/lib/php/extensions/no-debug-non-zts-20190902/zip.so"
elif [ "${php_version}" == "80" ]; then
extFile="/www/server/php/80/lib/php/extensions/no-debug-non-zts-20200930/zip.so"
elif [ "${php_version}" == "81" ]; then
extFile="/www/server/php/81/lib/php/extensions/no-debug-non-zts-20210902/zip.so"
elif [ "${php_version}" == "82" ]; then
extFile="/www/server/php/82/lib/php/extensions/no-debug-non-zts-20220829/zip.so"
fi
if [ -f "${extFile}" ];then
echo "extension = zip.so" >> ${php_setup_path}/etc/php.ini
fi
echo -e "extension = " ${extFile} >> /www/server/php/${php_version}/etc/php.ini
echo -e "extension = " ${extFile} >> /www/server/php/${php_version}/etc/php-cli.ini
/etc/init.d/php-fpm-${php_version} reload
