turantaib aaPanel_Kern Why are you writing the same advice? I said that you installed the paid plugin. I know for sure this is a problem with aapanel. There are no additional uploads on my sites. Will you help?
aaPanel_Kern Please make a server backup before deleting files to avoid errors that cannot be restored.
aaPanel_Kern If you are not using a plugin, you can check what directory is taking up space using the command line The panel is only a management tool, and generally does not generate a large amount of data to occupy space. This is generally the space occupied by your website or database turantaib
aaPanel_Kern Hello, from the screenshot, there is no directory occupied, it should be occupied by the running program, it is recommended to restart the server once, turantaib
