aaPanel_Kern aaP_isaacshisia Hello, it prompts that the compressed file does not exist, do you use security software? Is the hard disk space normal? Try to compress manually with the command tar -zcvf xxxx.tar.gz xxxx
aaP_isaacshisia I did click on fix then restarted the aapanel then it worked. However am experiencing challenge in installing mailserver and other plugins. Getting this and nothing happens. I upgraded to Ubuntu 22 as the 21 became obsolete
aaP_isaacshisia aaPanel_Kern Just deleted and tried again but still happening same way. I dont understand why,,this started after upgrading to ubuntu 22 since I couldnt install postfix and other required packages in ubuntu 21,, it kept on asking to repair
aaP_isaacshisia So can I downgrade to a lower version or how else can i access smtp relay or mail server
aaP_isaacshisia aaPanel_Kern Hi. I have tried that several times and it seems not work, it refreshes then shows same status
