Hi!
I'm suing a plug in called "Ninja Firewall".
It has 2 modes, one simply install and you are good to go. The second one protects even more things, but you have to add a php.ini override inside the Open litespeed server.
I tried commenting
//include /www/server/panel/vhost/openlitespeed/*.conf
//include /www/server/panel/vhost/openlitespeed/listen/*.conf
so I can edit... but after I remove the commenting dashs, the edited version dissapears.
Is there any way I can add that command inside the aapanel config for OLS?
Here is what I need to add
Log in to your Openlitespeed admin dashboard, click on "Virtual Host", select your domain, add the following instructions to the "php.ini Override" section in the "General" tab, and restart Openlitespeed:
php_value auto_prepend_file "/www/wwwroot/peixe.com.ar/wp-content/nfwlog/ninjafirewall.php"
Thanks!
