Hello, the intranet can be accessed, which means that aapanel is running normally, and the problem occurs in the network environment. It is recommended to check whether your network has a fixed IP.
Try to replace the forwarded port with another port. The panel uses port 7800 by default. Please check whether the forwarding is correct?
dragonhorde_team
