aaPanel_Kern Hello, try to check whether the network can connect to the download module node curl -vk https://www.npmjs.com/ aaP_privat
aaP_privat aaPanel_Kern It can Trying 2606:4700::6810:5d53:443... Trying 104.16.93.83:443... Connected to www.npmjs.com (104.16.93.83) port 443 (#0) ALPN, offering h2 .......... ect ect
aaPanel_Kern alfari Hello, try to check whether the network can connect to the download module node curl -vk https://www.npmjs.com/
webixes Hello, We are getting issue when we click on one click install but not working please help https://snipboard.io/VWEs9n.jpg
aaPanel_Kern Hello, do you use CDN or reverse proxy? Visit aapanel? Is it normal to try to install individual modules manually? webixes
aaPanel_Kern Hello, if you use the cdn proxy panel, some functions will not work properly, such as terminal and node module installation. webixes
aaP_ebiinesta98 aaPanel_Kern Hi, I don't use cdn and I have a problem with server ip again! I tested on two servers, but there is still a problem.
aaPanel_Kern Hello, I suggest you describe the relevant problem in detail and provide relevant screenshots. aaP_ebiinesta98
