aaPanel_Kern Hello, is it normal to wait a while? Is there anything wrong with the browser pressing F12? Is it working to try to click other functions of settings? macolinovo
macolinovo aaPanel_Kern I tried clicking on the tabs but everything is still blank, nothing appears on settings
aaPanel_Kern macolinovo Hi, try to fix the lower panel. Click Repair on the home page, can it be solved? Is it normal to try to change browsers and use incognito mode to access? Are you using a domain name to access the panel or an IP?
