ARNING: Running pip as the 'root' user can result in broken permissions and con
flicting behaviour with the system package manager. It is recommended to use a v
irtual environment instead: https://pip.pypa.io/warnings/venv
Starting Bt-Panel............failed
File "/www/server/panel/BT-Panel", line 10, in <module>
from gevent import monkey
ModuleNotFoundError: No module named 'gevent'
done
Starting Bt-Tasks... failed
File "/www/server/panel/BT-Task", line 13, in <module>
import task
File "/www/server/panel/task.py", line 19, in <module>
from psutil import Process, pids, cpu_count, cpu_percent, net_io_counters, d
isk_io_counters, virtual_memory
ModuleNotFoundError: No module named 'psutil'
File "tools.py", line 17, in <module>
import public,time,json
File "/www/server/panel/class/public.py", line 14, in <module>
import json,os,sys,time,re,socket,importlib,binascii,base64,io,string,psutil
Looking in indexes: https://mirrors.aliyun.com/pypi/simple
Collecting pyOpenSSl
Downloading https://mirrors.aliyun.com/pypi/packages/f0/e2/f8b4f1c67933a4907e5
2228241f4bd52169f3196b70af04403b29c63238a/pyOpenSSL-23.2.0-py3-none-any.whl (59
kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 59.0/59.0 kB 1.0 MB/s eta 0:00:00
Collecting cryptography!=40.0.0,!=40.0.1,<42,>=38.0.0 (from pyOpenSSl)
Downloading https://mirrors.aliyun.com/pypi/packages/19/8c/47f061de65d1571210d
c46436c14a0a4c260fd0f3eaf61ce9b9d445ce12f/cryptography-41.0.1.tar.gz (629 kB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 629.1/629.1 kB 2.8 MB/s eta 0:00:00
Installing build dependencies ... error
error: subprocess-exited-with-error
× pip subprocess to install build dependencies did not run successfully.
│ exit code: 1
╰─> [3 lines of output]
ERROR: Could not find a version that satisfies the requirement setuptools>
=61.0.0 (from versions: none)
ERROR: No matching distribution found for setuptools>=61.0.0
[end of output]
note: This error originates from a subprocess, and is likely not a problem wit
h pip.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with
pip.
Stopping Bt-Tasks... done
Stopping Bt-Panel... done
done
import task
import task
File "/www/server/panel/tools.py", line 17, in <module>
lrwxrwxrwx. 1 root root 37 Jun 26 12:59 python -> /www/server/panel/pyenv/
bin/python3.7
-rwx------. 2 root root 10270024 Jun 26 12:57 python3.7
-------------e-- python3.7
lsattr: Operation not supported While reading flags on python
ERROR: The BT-Panel service startup failed.
CentOS Linux release 7.9.2009 (AltArch)
Bit:32 Mem:924M Core:4
Linux localhost 5.4.72-v7.1.el7 #1 SMP Wed Oct 21 17:23:14 UTC 2020 armv7l armv7
l armv7l GNU/Linux
Please screenshot the above error message and post to the forum forum.aapanel.co
m for help
[root@localhost ~]# pip install --upgrade gevent
-bash: pip: command not found
[root@localhost ~]# pip3
-bash: pip3: command not found
[root@localhost ~]#
