aaP_hunter-38
/etc/init.d/nginx
#! /bin/sh
# chkconfig: 2345 55 25
# Description: Startup script for nginx webserver on Debian. Place in /etc/init.d and
# run 'update-rc.d -f nginx defaults', or use the appropriate command on your
# distro. For CentOS/Redhat run: 'chkconfig --add nginx'
### BEGIN INIT INFO
# Provides: nginx
# Required-Start: $all
# Required-Stop: $all
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: starts the nginx web server
# Description: starts nginx using start-stop-daemon
### END INIT INFO
# Author: licess
# website: http://www.bt.cn
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
NAME=nginx
NGINX_BIN=/www/server/nginx/sbin/$NAME
CONFIGFILE=/www/server/nginx/conf/$NAME.conf
PIDFILE=/www/server/nginx/logs/$NAME.pid
ulimit -n 8192
case "$1" in
start)
echo -n "Starting $NAME... "
if [ -f $PIDFILE ];then
mPID=`cat $PIDFILE`
isStart=`ps ax | awk '{ print $1 }' | grep -e "^${mPID}$"`
if [ "$isStart" != '' ];then
echo "$NAME (pid `pidof $NAME`) already running."
exit 1
fi
fi
#AAPANEL_FASTCGI_CONF_BEGIN
mkdir -p /dev/shm/nginx-cache/wp
#AAPANEL_FASTCGI_CONF_END
$NGINX_BIN -c $CONFIGFILE
if [ "$?" != 0 ] ; then
echo " failed"
exit 1
else
echo " done"
fi
stop)
echo -n "Stoping $NAME... "
mPID=`cat $PIDFILE`
if [ "$isStart" = '' ];then
echo "$NAME is not running."
exit 1
fi
else
exit 1
fi
$NGINX_BIN -s stop
echo " failed. Use force-quit"
exit 1
else
echo " done"
fi
status)
mPID=`cat $PIDFILE`
exit 1
else
echo "$NAME is stopped"
exit 0
fi
else
exit 0
fi
restart)
$0 stop
sleep 1
$0 start
reload)
echo -n "Reload service $NAME... "
mPID=`cat $PIDFILE`
$NGINX_BIN -s reload
echo " done"
else
echo "$NAME is not running, can't reload."
exit 1
fi
else
exit 1
fi
configtest)
echo -n "Test $NAME configure files... "
$NGINX_BIN -t
echo "Usage: $0 {start|stop|restart|reload|status|configtest}"
exit 1
esac
