curl: (60) Peer's Certificate has expired.
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
OS: el - 7
--2023-04-28 12:21:29-- https://node.aapanel.com/install/pyenv/pyenv-el7-x64.tar.gz
ERROR: cannot verify node.aapanel.com's certificate, issued by ‘/C=US/O=Google Trust Services LLC/CN=GTS CA 1P5’:
Issued certificate not yet valid.
To connect to node.aapanel.com insecurely, use --no-check-certificate'.
ERROR: Download python env fielded.
--2023-04-28 12:21:29-- https://node.aapanel.com/src/Python-3.7.8.tar.xz
Resolving node.aapanel.com (node.aapanel.com)... 172.67.171.7, 104.21.79.196, 2606:4700:3031::6815:4fc4, ...
ERROR: Download python source code fielded. Please try to reinstall
CentOS Linux release 7.9.2009 (Core)
Bit:64 Mem:58815M Core:8
Linux 62-210-100-111.rev.poneytelecom.eu 3.10.0-1160.el7.x86_64 #1 SMP Mon Oct 19 16:18:59 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Please screenshot the above error message and post to the forum www.aapanel.com/forum for help
[root@62-210-100-111 ~]#
