aaP_coder_dev After the ssl certificate expires, it is not possible to reissue it. In addition, the site started to give the error "ERR_CONNECTION_REFUSED". Fix, updating the panel didn't help. Restarting the server and the panel didn't help either. Please help
aaPanel_Kern Hello, please wait a day before applying for ssl. Or use other websites or other methods to apply for SSL Proxy, cdn, and redirection cannot be enabled using file verification aaP_coder_dev
aaP_carokey aaPanel_Kern The whole problem started when our SSL certificate was disconnected and we could not connect to the site, it just would not open and the browser gave the message "Unable to connect to the site", we have not touched or changed anything What is the problem?
aaP_carokey We decided to reinstall the panel on the server, it gives this error We rented a new server and got the same error The server is located in Moscow
aaPanel_Kern Hello, the picture shows that there is a problem with your system yum source, which makes it impossible to install unzip normally. It is recommended that you replace the usable yum source before installing aapanel The website cannot be accessed. It is recommended to check whether the web service is started? aaP_carokey
aaP_carokey aaPanel_Kern What do I need to do with yum? I don't quite understand Web service was running, problem appeared suddenly, panel tried restarting, updating, fixing
aaPanel_Kern It needs to be used to install aapanel. It is recommended that you ask your server provider to help you replace the available yum source aaP_carokey
aaP_carokey aaPanel_Kern What is the error of getting SSL certificate and why we lost access to the site?
aaPanel_Kern Hello, I can't judge without seeing the relevant logs. Is there any error message for the inability to access the website? aaP_carokey
aaP_carokey aaPanel_Kern The last thing we saw in the logs was the inability to access files, as far as I remember Now I'm reinstalling the panel.
