aaP_manuel.weiser Hey, i have some reverse Proxies running, with lets encrypt SSL enables. The Option "Auto restart Proxy on renewing" is enabled. Getting a new Certificate works fine, but the reverse proxy and force SSL isn't reenabled after renewing. regards Manuel
aaPanel_Kern Hello, click "Fix" on the home page to repair, and then check whether it is normal? aaP_manuel.weiser
aaP_manuel.weiser Oh, nice, it seems to be working. Manual renewing was fine now, I'll check if auto renewing works also. Thanks a lot 🙂
