Hi there,
I have enabled PERMISSIONS from DB menu to EVERYONE
I have whitelisted the servers ips on each other
I have opened the 3306 port to EVERYONE and tried SPECIFIED IP
I have turned off SSL and tried forcing SSL
I'm getting this error:
`Traceback (most recent call last):
File "/www/server/panel/BTPanel/init.py", line 1801, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1753, in run
File "class/panelDatabaseController.py", line 85, in model
result = PluginLoader.module_run(module_name,def_name,pdata)
File "/www/server/panel/class/databaseModel/sqlserverModel.py", line 90, in AddCloudServer
return self.AddBaseCloudServer(args)
File "class/databaseModel/base.py", line 281, in AddBaseCloudServer
res = self.check_cloud_database(get)
File "class/databaseModel/base.py", line 259, in check_cloud_database
return p.model(get)
File "class/panelDatabaseController.py", line 90, in model
raise public.PanelError(result['msg'])
public.PanelError: An error occurred while the panel was running: Traceback (most recent call last):
File "src/pymssql.pyx", line 636, in pymssql.connect
File "src/_mssql.pyx", line 1957, in mssql.connect
File "src/mssql.pyx", line 676, in mssql.MSSQLConnection.init
File "src/mssql.pyx", line 1683, in _mssql.maybe_raise_MSSQLDatabaseException
_mssql.MSSQLDatabaseException: (20004, b'DB-Lib error message 20004, severity 9:\nRead from the server failed (##MYIPHERE:3306)\nNet-Lib error during Connection reset by peer (104)\nDB-Lib error message 20002, severity 9:\nAdaptive Server connection failed (##MYIPHERE:3306)\n')
File "/www/server/panel/class/panelMssql.py", line 58, in Conn
self.DB_CONN = pymssql.connect(server = self.DB_HOST, port= str(self.DB_PORT),user=self.DB_USER,password=self.DB_PASS,database = None,login_timeout = 30,timeout = 0,autocommit = True)
File "src/pymssql.pyx", line 642, in pymssql.connect
pymssql.OperationalError: (20004, b'DB-Lib error message 20004, severity 9:\nRead from the server failed (149.28.173.33:3306)\nNet-Lib error during Connection reset by peer (104)\nDB-Lib error message 20002, severity 9:\nAdaptive Server connection failed (##MYIPHERE:3306)\n')`
