aaP_pinkth3floyd aaP_pinkth3floyd my aapanel is not working logged in with cmd downloaded the file and once i unzip it gives error maybe because of tamper protection and apache waf.. Please help me fix
aaPanel_Kern Hello, it is recommended to check whether the server network is normal. What message is displayed when I cannot log in to aapanel? Is it normal to change browsers or use incognito mode to access? aaP_pinkth3floyd
aaP_pinkth3floyd aaPanel_Kern cant login gets stuck here bt is working fine on cmd i restarted be service too.. nothing happened
aaP_pinkth3floyd aaPanel_Kern cant i disable tamper protection and apache waf from terminal? if its done i could have uploaded the zip.. even when i have root permission it is not allowing me to extract zip
aaPanel_Kern aaP_pinkth3floyd If waf and anti-tampering website upload zip are enabled by default, it has nothing to do with the panel. Is it normal to change browsers or use incognito mode to access aapanel?
aaP_pinkth3floyd aaPanel_Kern i unzipped code and it unzipped its fine for production... but my aapanel is still not accessible please help me fix this and please give me command to stop apache waf
taicao I cannot install Mariadb on Aapanel installed on a DigitalOcean VPS. I have waited for 30 minutes and only reached 18%
aaP_pinkth3floyd taicao is your machine intel or amd or arm? What operating system? Is your system latest? Have you monitored process log?
aaPanel_Kern taicao Hello, it is recommended to install mysql and use the quick installation method to install it.
