aaP_duyoka Hi, im using AApanel 6.8.27 on ARM CPU, i have 2 issues: I cant use nginx with NginxWAF or Nginx_Free_Firewall, for openresty, each time reboot server, Nginx service cannot start, i have to uninstall NginxWAF/Nginx_Free_Firewall first, start Nginx then reinstall them if i want to use. I cant install PHP 7.4, only 7.3 and 8.2. I tried to install via FAST and COMPILED method but no success. Anyone can give me more info and tell me how to fix this? thank you so much
aaPanel_Kern Hello, arm cpu only supports openresty, what information does nginx fail to start? check log systemctl status nginx What information does php7.4 fail to install? aaP_duyoka
aaP_duyoka Hi, thanks for replying me. Here is the error in execution log: I've just update to 6.8.28, but no luck.
aaPanel_Kern Hi, is it normal to try to install another version of PhP? Do you use compiled mode? The panel version has nothing to do with php aaP_duyoka
aaP_duyoka aaPanel_Kern Hi, no problem with another PHP version, this error only on PHP 7.4 try both Compiled and Fast mode and got same problem.
