norge @aaPanel_Jose not sure if anyone can help me. the domain is hosted and seen around the world the issue is cloudflare error and says its host error 522 much appreciated the help given
aaPanel_Kern Hello, 522 is unable to connect to your source server, can you try to solve it according to the official prompt? https://developers.cloudflare.com/support/troubleshooting/cloudflare-errors/troubleshooting-cloudflare-5xx-errors/#error-522-connection-timed-out norge
aaPanel_Kern norge Hello, please check if the database configuration of your website configuration file is normal? Also check if mysql is running and if mysql has a related database?
norge aaPanel_Kern yes i restarts but not fixed it i forgot the cmd though i can try to start sql from cmd line. as far as config.php where database name and db user and pass are its correct
norge aaPanel_Kern not sure but i do not use phpmyadmin, i use mongodb was not working with mysql seem to be same error
norge aaPanel_Kern 127.0.0.1:27017 <-------------- i saw i had to replace localhost where it said db host in wp-config.php now its just white page loads forever
aaPanel_Kern Hello, it is recommended to read whether the wordpress official document supports mongodb https://developer.wordpress.org/advanced-administration/before-install/ norge
