• Support
  • How can I get website speed 3.0 to work?
I want to use the website speed 3.0 tool, how do I use it? After installing Memcached, I installed it together, and Surplus does not decrease and 5000 remain. So the total rate and rate are the same. Can you tell me how it could work?
    Hi, check the site logs for any visitors?
    Does your website use encryption plugins?
    Try to reinstall website speed to see if there is any data after waiting for a while
    aaP_master0
    Thank you for answer. I reinstalled it and it seems to be working now. 😀
    a year later
    Are there setup instructions for Laravel? My website uses Laravel when I use "WebSite Speed ​​3.0" my website gets cookie error
